Toyo Proxes RA-1 tire sizes
Old 03-05-2007, 11:36 AM
ivai
ivai's Avatar
Default Toyo Proxes RA-1 tire sizes
I've got 16" wheels, 8" and 9" wide, front and rear respectively.
I'm planning on going with 225/50ZR16 for the front wheels.
On the rears.. I'm not so sure. Should I go with 245/45ZR16 or 255/50ZR16?
The 255 is .8" wider (according to the link below), but its also 1.4" bigger diameter than the 245 (due to the larger sidewalls).
If I go 245 for the rear, the fronts and rears will have approximately the same diameter.
Thoughts on pros/cons of the 245/45 vs 255/50 tires?
http://frisbyracetire.com/toyo_RA1_spec.htm
Old 03-05-2007, 11:41 AM
ivai
ivai's Avatar
Oh and by the way, I just noticed that on that site, its listed as "P255/50ZR16", whereas the others don't have a "P" at the beginning.
Old 03-05-2007, 12:03 PM
xsboost90
xsboost90's Avatar
p should just be perimeter...or something. I would do the 255/50s personally on an 9.
Old 03-05-2007, 12:09 PM
ivai
ivai's Avatar
The 8" wide wheel is up front.. the rear is 9" Finding wide tires for 16" wheels is hard.
EDIT: I see that you changed your post now..
Old 03-05-2007, 12:58 PM
Skip Wolfe
Skip Wolfe's Avatar
Go with 245's up front on the 8's and 255's on the rears with the 9's. I have used just about every combo available and I would go smaller than 245's all around. Our cars may be well balance but the like to push and having the extra meat up front helps. I used 255x17 and 275x17 on 8.5" and 10" x 17 wheels last year which worked out very well.
Old 03-05-2007, 01:51 PM
2bridges
2bridges's Avatar
ivai - I was faced with the same options,
I found two types of tires - pure street low performers and race.
To complicate matters I wanted a track tire that was treaded deep enough for rain use.
Found only one - Hankook rs212.
be sure to buy a trie for your use. After extensive research I found nearly every available tire in my size 245/45 was a severe performance compromise or race only.
have no high expectation for mileage, but that is the only drawback I identified
Old 03-05-2007, 02:36 PM
shiners780
shiners780's Avatar
I am glad to hear those sized worked well. I plan on ordering 255/275 later this week for my new 9"/9.5" X 17 wheels.
Old 03-07-2007, 01:37 AM
Acetylene
Acetylene's Avatar
"P " simply signifies a tire for Passenger car usage - you can ignore it.
Old 03-07-2007, 02:37 AM
333pg333
333pg333's Avatar
I'd be curious to know what appears to be quite a large differentiation in front to rear diameters will do. Sounds like Skip may have an idea? You guys still can't get the newer Toyo R888's yet huh? Also an excellent tyre and you may have greater choice in sizes? Having said that, what events do you compete in? Can you go up in wheel size? 17's or 18's give you much more to chose from.
Old 03-07-2007, 07:46 AM
thingo
thingo's Avatar
255/50 will affect your gearing, already pretty high in a stock 951, and they are going to change the balance of the car as well, you don't want the *** up in the air.Don't know if your concerned about your speedo reading either.
Old 03-07-2007, 08:13 AM
Geneqco
Geneqco's Avatar
Agreed... I'd be careful of the 255/50s... they also weigh more and whilst they are wider in overall width - with their higher profile, you may find there is actually very little tread width advantage, the site you posted did not say.
Old 03-07-2007, 09:16 AM
phils87951
phils87951's Avatar
I have been running, 245/45/16 on all corners for many years, it's a great setup. very neuteral.
Old 03-07-2007, 09:32 AM
xsboost90
xsboost90's Avatar
thats what im going with- 245/45/16 all around.
Old 03-07-2007, 11:19 AM
Oddjob
Oddjob's Avatar
Yep, to echo the last couple posts - go 245/45s on both the front 8s and rear 9s. A 255/50 is too tall a tire for the Turbo gearing. Any slight advantage of having another 10mm tire width is more than offset by the decrease in acceleration due to the larger tire diameter (adversely affecting the final drive gearing).
Old 03-07-2007, 11:46 AM
Skip Wolfe
Skip Wolfe's Avatar
Agreed - I wasn't paying attention and didn't realize the 255's had such as large aspect ratio when I recommend those for the rear.
Quick Reply: Toyo Proxes RA-1 tire sizes
