New Saikou Michi catch can installed.............
Originally Posted by 333pg333
Kevin, do you have any details on the head and cam? Is it going to be lumpy at idle for good or will you be able to tune that out?
Originally Posted by kasturbo
John, got the VRPB wired up and the car started first try. The idle is a bit rough, but that probably the cam.
You will need to adjust idle.
Originally Posted by SamGrant951
Awesome Kevin, your engine bay looks fantastic. Glad to hear its all back together for you...mine shipped out today I think.
kasturbo,
nice looking set up, was a check valve recommended with this particular can?
i have seen them suggested for turbo engines on another manufactures web site, thanks for sharing.
Originally Posted by fast951
Are you running the second image on the board? Or the first?
Originally Posted by reno808
How much did you pay for it? Where did you connect it to? LOOKS GREAT
Price was $80 with out the mounts and $90 with them.
Originally Posted by xsboost90
i realize this, i just thought maybe this was something new and revolutionary.
btw- is kasturbo aka por951turbo?
![](http://forums.rennlist.com/upload/saikomichiocc1.jpg)
Most of the recirculating catch cans out there have fairly small ports, while this is setup with 1/2" npt ports with 3/4" barb fittings to accomodate the larger AOS hose on our cars. Saikou Michi worked directly with a couple of us to make this can specifically for our cars. We are still working through a couple different mounting options, as not everyone can mount it in place of the washer tanks like Kevin did. Pricing is not officially set but will be under $100, which makes if one of the best priced catch can options out there, and as John aptly put it, it"does something other than be a shiny gadget".
Rennlist Lifetime Member
I'll be anxious to see this on your car - sounds like a good reason for a trip to the local pub. Let me know when you have it on ...I may end up doing the same.
Cheers,
Rick
Yes, I'm running the second image on the board. I figured I would have to play with the idle some, just haven't had time to do it. The afr at idle was still spot on. Is it typical for the vacuum to drop to 8 - 10 psi at idle with this cam? I pressure checked for leaks, but couldn't find any.
Unaffiliated
Looking great, Kev!
Originally Posted by Rick
Sam,
Cheers,
Rick
Cheers,
Rick
