18x11" wheel fitment on 86 turbo-GOT THE WHEELS
#62
Originally Posted by xsboost90
ok moment of truth- heres what it comes down to. 86 951 early offset. I used a set of bolt on 25mm front spacers and the fronts fit perfectly 18x8 235 tires. The rears are tricky. I put on the supplied 8mm spacers on the rear and the drivers side fit very well on either side, but the ps was rubbing the wheel well. Now i have some camber in the rear so this is understandable. I just ordered a set of slip on 15mm rear spacers hubcentric w/ longer studs so that should put them in just the right spot. Enjoy!
#63
oh- sorry. Fronts are 235/18 and Rears are 295/30/18 -cant remember exact sizes- 52mm offset front and 45 rear.
- im sure you could fill out the wheelwell fine w/ 10s - i prob would have got 10's if i found a deal on them, just need to put them on and see if you need small spacers or what...
- i put the wheels on w/ just small 8mm spacers and they rubbed slightly w/ some room so hopefully 15's will do it...
#64
oh- sorry. Fronts are 235/18 and fronts are 295/30/18 -cant remember front exact size- 52mm offset front and 47 rear.
#70
