GT35R installation question
Former Vendor
How much lower a Gt35R sits, in in other words, how much lower is the centerline of the shaft compared to one in a KKK, A) without the ATP Turbo's adapter and B ) with such adapter.
How much shorter is the Garrett's center housing compared to the KKK's? I can also live with a measurement of a center and a TO3 style turbine housing.
Measurements, not opinions, please.
The ATP adaptor is 1/2" in thickness so it raises the turbo up a 1/2".This means the downpipe and crossover pipe has to be modifed to fit the turbo.I have measured the actual center sections for the difference so I cant help you there.
Former Vendor
Thanks Tim. I know that both of them have to be modified and x-overpipe will be measured when I get the engine assembled. OTH I could get the downpipe done in advance, if I just could get to know how much shorter it has to be.
EDIT: After some searching I finally found that Edman's thread about GT30R installation. Very informative indeed.
Rocket Scientist
