Dynojet results
Originally Posted by toddk911
275/270 at the crank on 12 psi is pretty good, considering he is running almost stock boost.
Drive-by provocation guy
Originally Posted by LFA951
What do you consider working the fuel? New injectors? I have a new fuel pump and filter that I put in with the 3 Bar...
What kind of chips are you running???
Originally Posted by special tool
You are too lean starting at 2500 - do not raise the boost.
This is the main reason for the missing torque.
Your car is slow now - it might feel fast , but it is slow.
When you work the fuel, it will be quick.
Some sort of fuel controller. Piggyback or chips.
Monkeys Removed by Request
I agree you are missed a ****load of tq and power.
you're way lean. You need injectors. Buy some get the fuel sorted with a proper controller and then you will notice a huge difference in the way you're car pulls.
13's in the air/fuel is crazy lean.
Originally Posted by caster951
What octane of gas were you using to get pinging at 14 psi? I have done all of my dynos on 94 octane at 18psi with zero fuel issues. I am also curious to your afr of 12.1. That seems too lean if on the top end, imo.
Originally Posted by 944CS
no need for bigger injectors at your current power level, something must not be installed properly
if you are not looking for even 300 hp why go with a MAF?
You've already got the mods. I say buy injectors dial it up to 16-17psi and have fun with it.
regardless I would get that airfuel thing sorted. Thats dangerous
