Problems mounting To4e
When I put my T3/T04E in I had a the same problem. I had to play with the clocking a little bit and eventually just took a die grinder and ground down a little bit right around where it hit and it fit right in.
Originally Posted by special tool
That's where it is.
All he needs to do is pull one of the compressor clocking bolts (13MM atf) - 5 will suffice.
Thanks you guys for the tips, I ended up grinding down one of the housing bolts and having my wife pry on the turbo while I tried to line up the mounting holes. It finally fit. I have pics that I will post later. Some with the wife under the car. I'm such a lucky guy!
my wife came in the garage one day, I was on the creeper. I had a bit of grease on me, a bit of sweat, looked at her real sweet and said, "want to roll around a bit?" She took the groceries and went inside.
What can I say? It was the coolest thing I have ever seen. Neighbors did look at us kind of funny. As soon as I get back home, I'm posting pics so you guys can be jealous.
You guys have awsome wifes. My gf flipps out and says why dont you get a life a and get a car that doesnt break like a NEWER CAR. i tell her go up stairs and make a sandwich i am starving. 10 min later she comes down with ice tea and good sandwich.
A SMART girl knows a hobby tendency that keeps her man out of trouble (other panties) when she sees one.
