917 at LeMans
From what I've read it's also RPM-dependent: the compressor blades are more likely to stall at lower RPMs, however its less of a problem if you get hear the flutter noise at lower RPMs as the damage will be negligible. If you still get the noise at high RPMs you may be damaging your turbo.
how much damage is hard to say though. mine makes that noise and has done so for while(i like it) and while the turbo is off at the moment i have inspected it and found it to be in as new condition, besides the grubby fingerprints on the housing. we run with some of my friends that have R33 GTST skylines that have been running with no BOV for as long as ive known them to have the cars, in one case 5 years now and his turbo is still in good condition. so in theory it sounds bad for the turbo but in reality it seems little damage is done
Originally Posted by pa944red
I reread what I typed and I actually have a turbo XS DV and I still have that noise. How large of a DV do I need? And just to reiterate, I have a DV, not a BOV.
Tom
Tom
That is definately the sound I get. The sound is the same with a stock DV and my aftermarket one.
Funny you mentioned laggier turbos, I have a pretty laggy turbo.
I'm planning on swapping out the turbo for one that spools up sooner in the future, but until then what can/should I do to avoid surge?
Tom
Tom
i wouldnt worry about it, what you are getting is a form of induced surge. what i mean by this is that the turbo isnt causing the surge. you have a problem when it is the turbo, you know its the turbo when you are holding full throttle but the car is hesitating through out the rev range, also making that noise we are talking about at the same time. this for of surge is usually caused by the turbo running out of its compressor effeciency(usually too much boost, for the size of the exhaust housing and trim)
Hey anyone notice that Dereks car is Right hand drive also. See, we are correct 'down under'. Wonder where the shifter is as he takes his right hand off the wheel as if it's not quite tiptronic but he's certainly not grabbing a shifter down in the middle?
Originally Posted by JET951
off topic, hey porschefile, what turbo is on that RB26 in your avartar? is it a T51R or a T04Z. its HKS right
And here's a couple vids:
Vid 1
Vid 2
Many Porsche racecars were RHD (including for example 935 Moby Dick). Mostly it's because of the European circuits configuration.
