What makes a good DE motor.
Part of the IN Crowd
Ok guys
What changes from stock would you guys recommend for a 951 track engine?
I don't mean to gain HP I am more interested in gaining reliability.
I will start the list.
O-ringed Head or Block.
Oil Pan Baffles
What else?
Oil Pan Baffles
What else?
Good oil -- maybe an extra oil cooler and lots of oil changes.
Of course keep everything clean (you'll be able to diagnose and fix things faster and it will stay cooler).
Good quality coolant properly bled.
When not overstressed, and when maintenance has been performed religously and correctly, these engines will run and run and run and run.
Originally Posted by turbo8
dont you want it perp drilled,
whats the disadvantage of perp drilling? I had my last motors crank xdrilled perp on the rods just like the mains are from the factory. Installed the scraper and pan baffle and never had a problem afterwards.
anytime you starve the bottom end you are prone to spin a bearing or worse. These cars tend to do so when sticky tires are used because the oil sloshes away from the siphon for the oil pump -hence the oil pan baffle to keep oil around the sump. Drilling the crank keeps more oil on the bearings in case of temporary starvation, and the scraper keeps the oil in the pan instead of slinging around the bottom end.
I have experience spinning rod bearings.
That was not fun.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Too broad a question. You need to be more specific about the chassis, engine mods, rpm limit and driver skill/aggressiveness if you want an answer that will do you any good.
