wheels are all mounted
had some fitment issues in the front due to the offsets. in order to have them sit flush on the hub the dust cap was removed and 5mm spacers were added. there still arent any dust caps. so until we figure out what to use or what to have machined i wont get to drive the car till spring
anyway enjoy.
big thanks to kyle and ryan for all the help!
![](http://vwnuts.com/gallery/albums/userpics/resized2.JPG)
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
anyway enjoy.
I have used 996 wheels at the front in the past, but also had to run without bearing dust caps. I can only assume that the 996 bearing caps are different than the 944/968 series. Has anyone figured out an alternate bearing cap, that takes up less space?
I heard about your little "rub" issue. Hopefully you can find a tire combo that will work out better. Those things do look AWESOME though!
-vic
-vic
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
i ran 996 wheels on my 89 and it was either run spacers or run w/o caps- i ran w/ spacers but kept the caps on. You can always get alittle creative w/a 5lb hammer if they dont fit right. PUll the center caps on the wheels and see if they fit w/ the bearing caps on there.
any thoughts?
-vic
when i sold the wheels WadeB bought them and put them on his turbo S. As far as i know he put some 6mm spacers on there and siliconed the caps on w/o the greasecaps.
