Rx7 oil cooler - what year range for donor cars?
Old 01-11-2007, 01:03 AM
  #31
reno808
reno808's Avatar
can i do it as a lay a way form? seriously.
Old 01-11-2007, 01:13 AM
  #32
MPD47
The Carnage King
MPD47's Avatar
Already sold, sorry guys.
Old 03-06-2007, 06:08 PM
  #33
Depape
Depape's Avatar
Originally Posted by theedge
Ive got half a how to typed up, ill try to finish it at some point soon
The oil cooler from any RX7 TurboII will work.
These are the rest of the parts.
1x Weld On -12AN Aluminum Bung (Summit EAR-997112ERL)
1x 18mm x 1.5 to -12 AN Adapter (Summit “EAR-9919GFKERL”, Bat “AM18AN12”)
2x 22mm x 1.5 to -12 AN Adapter (Bat “AM22AN12”)
1x 18mm Port Plug (Bat “BPA2-85”)
1x 22mm Port Plug (Bat “BPA2-105”)
3x -12 AN 90 Degree Fittings
1x -12 AN 45 Degree Fitting
2 feet of -12 Braided hose
any update on the write up???
Old 03-06-2007, 06:32 PM
  #34
944Fest (aka Dan P)
Unaffiliated
944Fest (aka Dan P)'s Avatar
If anyone wants to add a cooler and keep the lineage intact, I have this oil cooler off a 95 Audi S6 I'll sell for $150 shipped. If you want to add another intercooler, you can have that for the same price. (shameless FS post)
Old 03-06-2007, 07:08 PM
  #35
anders44
anders44's Avatar
since this was woken up again, I will use a setrab cooler as they make them in loads of nice sizes, some compare to the rx7 cooler, meaning long, flat and basicly a regular very high with mounted sideways.
theese looks like good candidates, but will do some more measurments.
Dimensions in inches
PART # A B C D
1-STD910 16 14-1/2 3 2 aprox $126
1-STD915 16 14-1/2 4-1/2 2 aprox $166
1-STD920 16 14-1/2 6 2 aprox $206
Old 03-06-2007, 07:57 PM
  #36
billthe3
billthe3's Avatar
It looks like the rx7 cooler mounts up to the a/c condensor bolts, so does this mean you can only run the rx7 cooler if you've deleted the a/c?
Old 03-06-2007, 10:35 PM
  #37
mj951
mj951's Avatar
Pics and a write up would be great.
i've been working on a similar project, either a large central cooler or twin ducted coolers on either side of the radiator. the only issue i see with a central cooler is that it could reduce clean air to the radiator by as much as 2/3's. twin coolers would require moving the brake cooling ducts to the fog light slots and moving slightly the coiled hard line for power steering, so either option has its pros and cons, below are a couple of concept images for twin coolers. i've mocked this up a couple of times now and am leaning towards twin coolers run in parallel. i'll post pics if i get this up and running by spring.
Old 03-06-2007, 11:12 PM
  #38
Bri Bro
Bri Bro's Avatar
Twin setup (KISS) has been around for awhile and has been well tested.
Lindsey sells them.
http://www.lindseyracing.com/Merchan...TRANSOILCOOLER
Test data
http://944oilcooling.com/technical.htm
Old 03-06-2007, 11:52 PM
  #39
mj951
mj951's Avatar
beab, yes i have seen the kiss set up, this would be similar but different. pics are up now. i would replace the stock cooler for a 13 row mounted horizontally and mirror that on the drivers side. this set up has the coolers sitting lower with the bottom of the cooler lined up with the bottom of the radiator and the ducts running forward to the inlets on the front bumper.
Old 03-06-2007, 11:58 PM
  #40
theedge
theedge's Avatar
Ill try to finish off the write up later this week or next week sometime, I got really busy and forgot about it like I so often do Its partly done though.
Old 03-07-2007, 12:34 AM
  #41
reno808
reno808's Avatar
i am going with the dual 951 oil cooler as my friend gave me a turbo S oil cooler
Old 03-07-2007, 12:49 AM
  #42
Bri Bro
Bri Bro's Avatar
Interesting, I would like to see more as the project proceeds.
Old 03-07-2007, 04:43 AM
  #43
anders44
anders44's Avatar
when wireing in paralell will you do T or Y joints? how does pressure and flow distribution look for paralell vs serial?
my hope is that the single long cooler won't interfere to much with airflow for the radiator, and since oil is cooler it will get a tad bit less to do when cooling the turbo.
as for removing fogs' I need them since I've got plates on the car. and brakecooling is also needed. need more frontspace eh? will have a look and do even more measuremets.
setrab has M22 to -10 and -12 since the suggested BAT stuff is hard to get (at least here)
has anyone put a moroso oil accumulator into their system? I'm trying to find a spot to put a 3qt one, but it's 20 inches!
Old 03-07-2007, 05:28 AM
  #44
billthe3
billthe3's Avatar
For the problem of using the brake duct vents for the oil coolers, you could switch over to the 968 brake cooling vents - they scoop up air from under the car and don't require ducts. Someone on here got some recently...
Old 03-07-2007, 09:00 PM
  #45
mj951
mj951's Avatar
I plan to run -12 lines off the stock filter housing to a 'Y' splitter with -10 lines to each cooler and then back again, not sure how presure changes between a 'T' and 'Y' adapter but a 'Y' adapter must flow better. There are quite a few adapters required, i'll create a list once i have complete this project. Here are two diagrams of twin coolers in both series and parallel.
My car is both street and track, so i am looking for a clean solution to move the brake ducts up to the fog light slots, AIR has a pair on their web site, or as billthe3 suggests you could also use the 968 scoops.
Quick Reply: Rx7 oil cooler - what year range for donor cars?
