Rx7 oil cooler - what year range for donor cars?
Originally Posted by reno808
iS There are write a up on it? PICs??
regards,
AL
Ive got half a how to typed up, ill try to finish it at some point soon ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
The oil cooler from any RX7 TurboII will work.
These are the rest of the parts.
1x Weld On -12AN Aluminum Bung (Summit EAR-997112ERL)
1x 18mm x 1.5 to -12 AN Adapter (Summit “EAR-9919GFKERL”, Bat “AM18AN12”)
2x 22mm x 1.5 to -12 AN Adapter (Bat “AM22AN12”)
1x 18mm Port Plug (Bat “BPA2-85”)
1x 22mm Port Plug (Bat “BPA2-105”)
3x -12 AN 90 Degree Fittings
1x -12 AN 45 Degree Fitting
2 feet of -12 Braided hose
Thanks for the info Brian. I had been specing out something a bit out of the ordinary with Mocal, but this fits my needs perfectly as I want to use the spot in my pig nose for an oil cooler now. Lindsey intercooler is gone for the NA Swap (obviously) and because im working on a new setup for the next turbo motor.
Originally Posted by Moook
Rolex, Was it this one...
https://rennlist.com/forums/showthre...ht=oil+coolers
Im just looking into doing something similar...![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
![](http://www.rs6.com/smilies/cheers.gif)
Originally Posted by Duke
Brian, what was you reason for welding on a different port rather than just using the stock ones?
THE EDGE so what your saying is that you need to weld that fitting in their to make it work "well" right?
