Suggestions for removing door rub strip???
the one that is on the outside of the door.
I've got the strip off but can't seem to remove the adhesive.
I've tried Goo Gone but it doesn't work.
Any suggestions short of a wire brush??
Thanks.
Thanks.
Originally Posted by EdC
If is like the stone guard glue, let the 3m stuff work on the snotty stuff and scrape off with a plastic razor blade, and when it's all off, continue to use 3m but use big pencil eraser to get the remaining stuff off.
It took me about 7 hours to get it all off.
There is a tool that goes on a drill, in UK its called a "Caramac Wheel" Its like a yellow hard rubber ring that seems to remove tough adhesive and trim lines without dmaging paint work
