Ticking at start up!
Last week I changed my oil with Valvoline Racing 20/50. Last night I started the engine and heard a loud tick tick tick tick tick and then I guess oil pressure finally built up. What would cause that? I'm not trying to restart a thread on synthetic vs. dyno but I never heard this horrible sound before using Valvoline. I think I'm going synthetic.
Originally Posted by TRP951
Did you just change your oil after the car sat a while? it might be the lifters pumping up if it went away after a little bit.
That was my thought. Does it sound like it's coming from the top of the cam housing? vary with rpm?
Pumice King
I have a similar sound at start up, and I use 0-40.. It's also been cold here in Michigan, but when I get back to Arizona things should get better?
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
20-50 is very heavy oil, but it is the CORRECT oil.
It is normal to have lifter ticking on a 1 week startup in 40 f temperature with a fresh change to 20-50.
Streck - 10-30 is too light for a 951. I don't care what the temp. is.
Your bearings will suffer premature wear from lower hot oil pressure.
Mexican Ambassador
i get this almost every morning cuz my dumb *** left the 20-50 in there and at night everything gets frosted over.
when i get ice on the windshield, i guess it's time to change the oil, eh?
