long cranking time to start possibly timing belt?
Originally Posted by PorscheMD
I can see the reference mark sensor having problems when the engine is hot if the sensor is in bad shape. (i.e. the shielding cracked) but if the gap is what is wrong, then that will be a longer cranking time to start when cold.
Very true.
Originally Posted by The DareDevil
That's not a timing belt issue. The timing belt spools the water pump and (obviously) keeps the cam(s) in time with the crank.
When it's cranking, does it stumble while cranking and then slowly stumble to idle... Or does it crank for a long period of time and then just fire up instantly?
Also, when it's cranking and not starting, does the tachometer needle bounce at all? It's normal for the tach needle to pulse slightly while cranking. If it isn't, that's a problem.
[Edit] Timing belts should be checked and changed at regular intervals![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
