Lots of guys have asked me, ''why not use more than 40% xylene?".......
Old 12-19-2006, 10:43 AM
  #61
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by mwc951
I sell reagent grade Xylene to hospital, reference & acedemic laboratories. It's very nasty stuff, way harsher that Toulene. Medical labs use the stuff to process tissue. So if you have a biopsy taken, the tissue is put into a tissue processor w/reagent grade xylene, formalin & isoporpanol. The tissue is then "cooked" so it can be cut and slides made to then send to the Pathologist. Due to recent OHSA/CETA regs most hospital labs have been forced to purchase $30,000 xylene recyclers so the used up stuff can be disposed of properly. Before this, they paid as much as $250/55 gal to get rid of it. So if any of you guys get to know your friendly local Histology Tech, there should be an unlimited supply of Xylene.
I'll stick to 100 octaine.....Xylene is a known & powerful carcinogen.
"Histology Tech"
Know of one in Orlando?????????
Old 12-19-2006, 10:48 AM
  #62
RolexNJ
RolexNJ's Avatar
Originally Posted by toddk911
"Histology Tech"
Old 12-19-2006, 10:49 AM
  #63
toddk911
toddk911's Avatar
Originally Posted by Mike1982
Well, xylene is what, 117 octane? So, if you put in let's say 93 at the pump you just times the amount (gallons) times the octane (93), then do the same for the other agent. After that is said, you divide by total gallons in tank. Ex:
Fuel : 10 Gallons at 93 octane = 930
Fuel 2 : 1 Gallon at 117 octane = 117
Total Octane : 1047
Total Gallons (if dry when filling) : 11
Octane per gallon : 95.18
Now, as ST said, you never want to run more then a 40% because of glazing on the spark plugs but I see some are running 25% xylene. Running a 25% mix you yield a 99 with 93 at the pump. Bump up to 94 at the pump and 25% xylene would get you 99.75. At max 40% on 93 would get you 102.6.
And 1.5 octane per psi boost increase to be safe.
I always rememebr a 3:2 range. 3 octane increase and you can run 2 more psi of boost.
Old 12-19-2006, 10:51 AM
  #64
toddk911
toddk911's Avatar
Interesting points I wasn't aware of from the Vette site:
The effect additional toluene or xylene has on pump gas is unpredictable for two reasons:
1) the octane boosting ability of both is less effective on premium pump gases than on regular grade gas because of the aromatics premium gases already contain,
2) toluene and xylene have high octane ratings alone but may have lower octane when blended with other gasoline components and must be carefully tested when mixed with other gasoline components.
Toluene and xylene have specific gravities higher than pump gas so the more of them you add, the leaner you need to calibrate the engine’s air/fuel ratio. (so you have higher octane and are "chemically richer" ???)
Once you calibrate for toluene- or xylene-spiked, DIY racing gas; don’t go back to running conventional gasoline until you recalibrate to a richer mixture or you’ll be burning pistons.
Old 12-19-2006, 12:43 PM
  #65
RolexNJ
RolexNJ's Avatar
Here's a pic of what Special Tool's car looks like after he uses xylene and starts it up.
Yikes --->
Old 12-19-2006, 03:22 PM
  #66
Rock
Lazer Beam Shooter
Rock's Avatar
Yikes --->
Mein Herz Brennt!
That is AWESOME!
Old 12-19-2006, 03:37 PM
  #67
RolexNJ
RolexNJ's Avatar
Originally Posted by Rock
Mein Herz Brennt!
That is AWESOME!
But don't drink that stuff --> Special Tool
Old 12-19-2006, 03:39 PM
  #68
toddk911
toddk911's Avatar
Down hiya in tha South we refers to that as "Shine"
Yummy!!!
Old 12-19-2006, 03:40 PM
  #69
RolexNJ
RolexNJ's Avatar
Yummy!!!
Yeehaw! --->
Old 12-19-2006, 04:07 PM
  #70
mwc951
mwc951's Avatar
toddk911..........
Sorry I don't know any Histo Techs from Fl.
Just go to your local hospital and tell'em you
are there to recycle their Xylene. Likely
they give you barrels of the stuff. Reagent grade too!
BTW........
WV shine = 114 octaine
FL shine = 87 octaine
Old 12-19-2006, 04:39 PM
  #71
toddk911
toddk911's Avatar
toddk911..........
yea, but isn't the Xylene fro mthe hospital already "used"?????
BTW........
But we have more flavors!!!
Old 12-19-2006, 04:40 PM
  #72
toddk911
toddk911's Avatar
Yea, but isn't the Xylene from the hospital already "used"?????
Old 12-19-2006, 05:15 PM
  #73
RolexNJ
RolexNJ's Avatar
So, it's more pure than the industrial strength. Who cares if it had AIDS in it or other leathal diseases, use it in the car! I know ST would!
Old 12-19-2006, 05:53 PM
  #74
special tool
special tool's Avatar
I would
Old 12-19-2006, 06:04 PM
  #75
RolexNJ
RolexNJ's Avatar
Originally Posted by special tool
I would
OMG. You start this thread you fat bastard and say like two words? You are unbelievable!!! You kill me...
Quick Reply: Lots of guys have asked me, ''why not use more than 40% xylene?".......
