Front wheel bearing maintenance
UAE Rennlist Ambassador
Would the front wheel bearing(s) benifit from being disassembled, cleaned and repacked with grease (just like the CV joint) or that would be just a waste of time?
Note: they are fine, just a general question since i never saw anyone (manuals, forums) mention this.
Originally Posted by PorscheDoc
It should be done on a yearly basis (if your car is a DD) in my opinion. It only takes a half hour or so.
DD, daily driven?
Originally Posted by beab951
I inspect and repack the front bearings and the hubs every spring. Cheap insurance.
Originally Posted by hosrom_951
DD, daily driven?
That's good to know, it is moly base grease that should be used, like the CV's right?
Originally Posted by pa944red
Please forgive me if this is a dumb question but, do you guys replace the seals every time you do this?
Tom
Tom
Jim: Just browsed clarks garage for this, it is also mentioned there that the grease is moly based, which is what i used for the CV's, it is black in colour......
The 'wheel bearing grease' i see sold locally is oil based (dark yellow in colour), i always thought moly based grease is better than any other grease out there, since it has a higher heat range.
The grease is moly based, black as coal. If you get it on your skin it is really slick and hard to completely remove. I replace the grease seal and inspect the bearing and repack the grease. I replaced both front and back bearing this spring so they should be good to go for some time. The car does around 30 DE days a year and is driven as a DD when the weather is nice.
CV joint and wheel bearing grease are not the same thing. Having messed around with both wheel bearings and CV joints more than I care to remember, the consistency of the two greases is not similar at all. I predict you will have very short lived wheel bearing life, if you dare to pack them with CV joint grease.
Most of the wheel bearing grease I have used, both synthetic and non-synthetic has been red, but a dark charcoal/black color is also common for non-synthetics.
Wheel bearing grease (first few hits off Google):
http://www.timken.com/industries/aut...s/wbgrease.asp
http://www.syntheticoilnlubes.com/am...grease_gl.html
http://www.mobil.com/Canada-English/...tic_Grease.asp
http://www.pennzoil.com/products/gre...m_707_red.html
http://www.pzlqs.com/Tech/Pdsheet/Qu...gLubricant.PDF
http://www.bakerprecision.com/neowhl.htm
http://www.nextag.com/wheel-bearing-grease/search-html
CV Joint grease:
http://www.prostreetonline.com/oem/q...tion=000268367
http://www.pegasusautoracing.com/pro...asp?RecId=3008
CV Joint grease:
What I have been using is made by Valvoline and is a semi-synthetic Durablend grease which as a lithium thickener, is moly-fortified and is a dark color. Its applications include wheel bearings and CV joints.
http://www.valvoline.com/products/Du...d%20Grease.pdf
The Valvoline full synthetic is also a dark gray color and has applications of wheel bearing and CV joints.
http://www.valvoline.com/products/Synpower%20Grease.pdf
Redline makes a grease that is red in color and it applications include wheel bearings and CV joints.
http://www.paragon-products.com/product_p/rlcv2.htm
