Broken 944 turbo :-(
i had the rear wheels up on another set of wheels that i have for the car about 1' up. Then i jacked the front up as far as i could, put jack stands under it, put a 8" spacer block on my jack and jacked the front of the car up some more by the frame rails behind the fenders.... Then put the jack stands all the way up under those rails...pretty high. Lowered the motor down on an atv jack, before i lifted the car all the way up, then raised it. Dropped the atv lift and rolled it out through the wheel well hole- or out the front i had the bumper cover off too.
well my land lord just said that she wants her barn back so now i dont have anywhere to do the engine drop. she gave me a week so i might be able to do it today or tomorrow, but not sure.
i have the front and back lifted right now.. the bottom of the engin is about 18 inches off the ground.. will i be able to get it out with it that high or should i jack it up further?
looks like in the pics you took all the steering stuff out too.. is that nessiary or do i have to do that? since i cant use the barn anymore i was hoping to take the engine out and then put the wheels back on and roll it out in the the driveway and keep it there... anythoughts?
-Tim
-Tim
Hi I had a question
were did you get those stands?.............are they for trucks, and how high those it need to be for the engine assembly to clear the chassis?
thanks alot.
Regards,
AL
