Fixing drain at gas cap
I was hoping for some tips as to how you have managed to install the rubber drain plug that captures excess gas and water inside the gas cap? I have the original rubber 'plug' which connects to a metal hose, which connects to the regular porsche hose. The rubber plug doesn't sit firmly enough to block out water, and I was wondering if it should be caulked to prevent water from seeping in. Any thought? Anyone have a pic of their draining system (car draining system that is)?
I picked up a new one at the dealer. The new one was bigger and fit tight. Use a little lube when installing. If you remove the trunk carpet, you can reach up in there and disconnect the drains. Common leak point on 944's.
Tom
'87 951
Tom
'87 951
