Alarm install, automatic door lock prob???
I just bought an alarm and keyless entry, install went smooth for everything except for door locking, not unlocking just locking. Well about a month ago when i turn the key in either door to lock, they both dont lock, and its hard to lock, (no electronic aid) but my console switch worked so i figured if i got keyless it would work too, not the case.
I have a diagram that says ground the brown/white wire to unlock which works fine, but it says to ground the brown/red to lock, which when i directly grounded it it locked the first time but then never again, the next day i tried again and it lock once and only once. What is the problem, is it the microswitch in the doors or something way diff?
I discoverd a really easy way to pop the hacth with keyless systems which i will post instrucitons for tomorrow.
