17psi...in first gear!!! :)
Drive-by provocation guy
Yep, gotta love the cold air ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Was about 45-50 degrees here so I got on it a little this morning. With the few cold days we get down here I think everyone with a turbo'd car goes out to drive when ever they can when it's cold.
So I run 18-19psi and was just curious to see how much boost I could build in first gear with the cold air and right at redline I saw 17psi.
Cast Iron Man
15psi here in 40 degree weather yesterday! Got 16 in 4th and I normally have it set at 15 so I may need to dial it down a bit. Of course I'm going to change the oil tonight and put it in winter storage tomorrow.
Originally Posted by Zero10
17psi at redline....
I want your car
I get 5![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I want your car
I get 5
Even when stock setup and no MAF and in the cold I could get 15, when I was running 18 like I am now.
Originally Posted by SD Porsche Fan
15psi here in 40 degree weather yesterday! Got 16 in 4th and I normally have it set at 15 so I may need to dial it down a bit. Of course I'm going to change the oil tonight and put it in winter storage tomorrow. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Colder air is denser; turbo and IC run more effeciently with colder intake air and colder air flowing over them.
Well, IIRC you can run 1 additional psi for every 15 degree drop in intake temps and not need to make any a/f changes or octane etc.
So if they are like -50 below, that is possible?????????????
Originally Posted by special tool
Wow - great thread.
I just burned down the Sawmill Parkway - I was getting 29 psi in 4th at redline (7000)
It IS cold today..........
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Well, you run 25psi right? So your getting about 4 more from the cold?
Temprarily Banned per IB
LOL!
No, I wouldn't even tell someone that joking, because they might not know any better and try it!
I ran 24-25 on my old car, I actually ran 30psi once to see what would happen...
This new one is still sitting in the driveway waiting for lots of work to be accomplished on it.
When you were running 24-25, was that daily driver and/or you car at those levels on a steady basis? or just a once in a while thing
Originally Posted by toddk911
Are you serious???? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Totally serious.
Been running 28 costantly for almost 4000 miles now - just to break in the new turbo.
![](http://www.rs6.com/smilies/woohoo.gif)
I guess if we all had unlimted supplies of Xylene we would also ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Well, I guess not with stock head/studs though....right?
What is most you run with pump?
