klr and explosive dist cap please help!
Old 11-01-2006, 06:34 PM
amschnellsten
amschnellsten's Avatar
is there anything that can burn up a klr. I Know one is could be bad due to water damage.
Old 11-01-2006, 06:35 PM
fast951
fast951's Avatar
Make sure whoever is testing your KLR does not have the Vitesse Wasted Spark system. It will not be a 100% valid test.
John
Email
www.vitesseracing.com
Old 11-01-2006, 06:38 PM
amschnellsten
what does your wasted spark system do?
Old 11-01-2006, 06:42 PM
fast951
fast951's Avatar
It eliminates the coil/distributor/rotor, allows you to use a coil-pack or coil-over-plug for a hotter spark.
As a side benefit, if the DME has a bad final ignition driver, the WS still works.
Be aware, that the WS will not solve the problem you have.
Old 11-01-2006, 10:58 PM
Bri Bro
Bri Bro's Avatar
Strange that two different KLR didn't work. Did you check all the power and ground connections to the KLR? If the KLR wasn't powered correctly, the output from the KLR that go to the DME for timing could be floating and that could cause the input to the DME to start oscillating causing the continuous spark generation.
Old 11-02-2006, 07:40 PM
amschnellsten
I will check the power and grounds again. does anyone want to try out a klr in their car.
Old 11-04-2006, 08:48 AM
amschnellsten
I checked my grounds and power yesterday going to the klr pin 12, 11, 10 did not have ground. I checked them with the klr unplugged. do I have to check them with the klr plugged in? Or is this the problem that I am having. Does anyone know where these ground points are in the car. Pin 14 is getting a good ground. help this is so dam frustrating.
Old 11-04-2006, 07:21 PM
Bri Bro
Bri Bro's Avatar
Sorry, I am out at Mid Ohio this weekend. Somebody should be able to look this up in the manual.
Old 11-04-2006, 09:50 PM
hally
hally's Avatar
might be of use:
Old 11-06-2006, 02:31 AM
Bri Bro
Bri Bro's Avatar
Thanks Hally
Quick Reply: klr and explosive dist cap please help!
