Is there a "better" turbo seal?
Originally Posted by Over Boost
I dont know I guess im doing both.
Also what else should I change while its apart? Im changing the oil feeder line and all the seals on the turbo. What else might be leaking in that area? I have some oil in the area of the head gasket and im not sure if its leaking or if it could be something else in that area or the seal maybe just blowing oil over there. How much harder would it be to also change the head gasket while im in there? I mean if its not too much more work I might as well change it while I got the intake off right?
Oil in the turbo area could be coming from the throttle body. There is always some oil present in the intake of a turbocharged car, and when the seals on the throttle body fail some can be blown out and drip down onto the top of the turbo.
Just curious, but where did you get your oil feed line from, and how much did it cost? Mine is leaking like crazy.
Originally Posted by shiners780
AOS seals?
I also replaced the o rings on the oil tube ( not an easy job for the faint of heart ) Its a PITA if you are concerned about breaking the small tabs at the top of the tube. So you have to be careful...
The O rings can be gotten from Scott Gomes
