Boost problems....SOLVED! (G-Tech update!)
Some of you may recall some of my posts about my frustration with my LACK of boost - I couldn't get more then 8-9 PSI....Thought it was with my APEXi or, as was suggested by some others, wastegate.
Well...my wrench and I have been working to find the cause (before springing for the $ for a new WG)...
Thank goodness, he found it - SIMPLE PROBLEM! The Pass side boot on the intercooler had a split on the underside!
I am now getting a SOLID 15-16psi!!!!!! And spool up is RAPID!!
SONOFABITCH....THIS THING IS QUICK!!!!!!!!!!
YOWZA!
(Dammmmm....I am so pumped...I may blow off some work today and head out some country roads!!!)
{can you tell I'm a bit pumped?!?!?}
YOWZA!
Hey don't wreck it on the "Back country Roads", but have fun!
Yes, I have sepnt the last week trying to fix the Barometer in my car aka boost gauge. Only to read and bit and understand that when I turn the key on prior to start it is telling me the barometric pressure, and my not be at 1 on foggy days first cold start, and my alitutde might make it register .995 BAR at start rather than perfect 1.
OMG In the moring I can predict the weather with my Barometer!
Took her out and did a G-tech run. (Not sure of my exact weight - I used 3120#)
296.5 HP
278 ft/lb
0-60 5.05sec - and I didn't get a GREAT start - but decent (I was being too mindful of the clutch dumping thread!).
This is ALL with NO APEXi or A/F tweaking...
I think she can easily do 0-60 in 4.7ish with a little practice!
296.5 HP
278 ft/lb
Drive-by provocation guy
"Yes - the windshield banner in my avatar is REALLY on my car! NO PhotoShop here! "
PLEASE!!!!! tell me where you got that windshield banner?????????
That is one of my biggest pet peeves of drivers.
I have also thought about the front plate's that say, in backwards writing, "MOVE OVER"
So, found ya some lost boost huh???????![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Usually when those IC coulpers split it alwasy seems to be on the underside.
I might have to break out my G Tech again with my new chips in. What gear did you do your hp pulls for the G Tech?
Toddk -
The windshield banner came from edecals.com. At almost any car gathering, it is one of THE MOST TAKEN pics!
The G-tech does a calculation on peak HP - regardless of gear.
Lastly - The ARC2 can be 'tuned' (sorta) by assometer....but - you really need some sort of A/F meter guage to be sure...
Mark,
How did you end up finding the boost leak? About a week and a half ago, my boost started running out at 5-7psi and I have what sounds like the BOV valve going off and continuing to stay open while the boost didn't build or would build very slowly (i.e. massive boost leak) after that.
I am curious how you diagnosed the leak?
Congrats on fixing it!
"The G-tech does a calculation on peak HP - regardless of gear."
Yea, but the method is by an accellaromter and it measures, IIRC, the "pull" of the car. So in lower gears there is more of a pull feeling than 4th or 5th.
I know sometimes I would get readings all over the place depending on how you got on the gas, etc. Some would say 150hp then some would say 300+ hp.
Were your results straight from the GTech or did yo utranspose to crank hp in your post?
From the gtech...so crank hp would translate something around 350-365 (assuming a 15-20% drivetrain loss).
Nonetheless - the ASSOMETER was 'pegged' and the 5 second 0-60 (albeith with a not-so-great launch) is enough to convince me!!
Maciek -
We just kept eliminating things...actually pulled the connecter off of the wg, and applied a little air pressure to make sure she was working, check vac lines, fuel pressure, etc...Once we confirmed the WG was working properly - we felt it HAD to be a leak somewhere.
Kept wiggling hoses, and noticed that that coupler 'wiggled wierd'
...the ARC2 is just it's own animal when trying to tune ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
