89 951 dyno chart
#31
ST, did you ever think about raising your compression ratio so that you don't have to run 28+psi to achieve the power levels you want? This would lower your intake temps considerable if you only had to run 1.5 bar max
#32
It's easy to get fooled by the flat tq curve of those turbo's.
Personally I'm all about flat tq curves and top end VE but the reason the tq curve is so flat on those dyno's aren't because the engine has better VE but because the turbo is too big to get decent midrange. The curve is flat, but low. Not saying they're bad charts, just that some people (me included!) first got fooled by the flat curve and thought the engine had some nice VE improving mods.
#33
Exactly. I wasn't being fooled by this, I was just a bit surprised as about 99% of the 951 dynos out there always have torque dropping off significantly on the top-end, so I was beginning to think it would be a huge pain to maintain torque on the top-end. I guess I underestimated the capability of just running a big @ss turbo! Of course further VE increasing mods will only help this.
#34
Guessing again?
When will you prove yourself right?
#36
Basic Sponsor
Originally Posted by George D
When is the wrestling match between you two? Do you guys know each other?
George
George
#37
Originally Posted by special tool
Guessing again?
If I only had a dollar for every time we've quoted each other!
#38
I've never heard anyone say that they have a 500hp 951 using stock injectors, or use the stock exhaust for a 400whp car. I've never heard anyone say that their 400whp car will take a 700hp car, at least not a drag type race.
What are you talking about?
G
G
#39
Monkeys Removed by Request
G
G
#40
G
G
Hehe, maybe you missed some of the threads in the last few months:
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/320628-8-valve-500-hp-944-turbo-excellence-82-dec-1998-a.html
Okay well, that was the only one I could find after a quick search. Anyways, there are plenty of ridiculous threads like that in the 951 section and strangely enough there is usually never a lack of people to support ridiculous claims with no hard evidence or basis in reality. I guess that's just the internet for you.
#41
Formula One Spin Doctor
We are all a little perplexed. The dyno charts prior to the 951 MAX chips were not this good on the tq curve. We did four runs and the tq curve was the same. Even if the dyno wasn't right, having 350tq at 6500 is bizarre on a 2.5 motor.
This dyno is certified for the Supra shootouts and they have 9 second honda at the shop. They are the read deal when it comes to the rice community. Some of the fastest Supra's in the world are built here.
George
George
the continuous climp of the hp and the flatening of the T/Q shows the possibility of the boost climbing with rpm .
what was the boost level at 4000 rpm vs 6500 rpm
#42
http://forums.rennlist.com/rennforu...ad.php?t=320628
Well, looks like you are talking to someone that lives here in AZ, and personally knew Cervelli, and Rains. I, personally saw Graham's car, and it did have this power on stock injectors. Powerhaus and Technodyne (Cervelli) helped build my first 89 951 back in the day, and we were running 350 wheel hp on stock injectors. Graham raced his 2.8 89 951, and I know it was very reliable. So, yes, you can get 400whp using stock injectors. Best setup, no.
Cervelli had an original factory 968 Turbo 3.0 in his race car and was usually number one in points in NASA.
This is not a very good example of what you are trying to state.
George
George
#43
Small Business Partner
George
George
Rogue
#44
Not gonna happen. I just had to stick up for some of the best 951 tuners during the early days of these cars. Cervelli and Rains did alot of R & D back then. They were some of the first to put bigger turbos and such on these cars. They even worked with Autothority to make the first MAF system and chip upgrades. Cervelli was the first tuner to put Garrett turbo's on our cars.
I remember when they were running 300whp cars and I had a 85.5 NA 944. I would just drool over seeing their cars. That was 18 years ago. I was in my mid 20's. I didn't get my first 89 951 till I was about 28 and they helped me get that car to run.
I took such good care of that car. It's now in LA with a 3.0 going in as I type. That car is going to be a monster.
I'll shutup now.
George
I'll shutup now.
George
