Need help to tune Greddy Profec Type S EBC
Hey guys,
I just installed a Greddy Profec Type-S electronic boost controller. I'm running a Tial 35mm dual-port wastegate with a 12 psi spring. With the "Gain" left in the factory position (9 clicks from full counter-clockwise), I started to adjust the "Low" ****. I set it at 15 psi of boost, only took a few clicks from full counter clockwise to get there.
The problem was in setting the "High" ****. Even in the minimum position (full counterclockwise), my boost shot off the scale on my Autometer boost gauge (i.e. >20 psi). Is there any way to recalibrate this thing so that I can use the "High" ****? I'd like to set it at about 18 psi.
BTW, boost hits extremely fast with this EBC, much faster than my old black **** manual boost controller.
I figured it out! The solenoid valve unit comes with three ports, labelled "COM", "NC", and "NO". Using a dual port external wastegate, you end up using the "COM" and "NC" ports, but nowhere in the instruction book does it say to remove the plastic plug that covers the "NO" port. After some serious overboosting trying to set the High ****, I've figured it out. Remove the plug to allow the "NO" port to vent, and she works like a charm.
Hey Man
Temprarily Banned per IB
Regards,
Russell
It works well now that I've pulled that plug. The boost needle shoots up towards the set boost level at an incredible rate, comes on much quicker than with the manual boost controller (black ****).
My only concern now is regarding where I mounted the solenoid, or as Greddy calls it, the "Boost Control Valve". The instructions say to mount it somewhere where it won't get hot or wet. I installed it inside the engine compartment, right below the VIN number. It's a perfect spot as far as routing hoses and available space is concerned, but it is within the engine compartment and not too far away from the headers. Hopefully that won't be a problem.
Regards,
Russell
Hey Man
Originally Posted by rberry951
On my friend's car it is mounted to the passenger side strut tower, it's been there for at least 3 years that I know of. There really is NO place under our cars' hoods that isn't hot.
Regards,
Russell
Regards,
Russell
