Lightweight Battery in Excellence
Does anyone have the last couple of months of Excellence laying around? Supposedly there was an article where they put in a lightweight battery into a 944, and I need to find what the part number is (I guess it can be gotten at Advance auto). I would guess it is in the white 944 that is usually towards the back of the issue getting something done to it. I seem to have every issue but july and august of this year, so it must be in one of those.
Thanks in advance!
Thanks in advance!
Karl, I looked it up on their web site, its in the Aug 2006 issue. I should be home tomorrow early evening, I'll call when I am getting close.
Regards,
Regards,
Thanks in advance!
Thanks in advance!
I have the ETX14. I've done 4 track days with it so far and it's works absolutely fine. No problems starting whatsoever and I haven't used my float charger at all between events. Keep in mind my car is track only: no radio, power windows, headlights, etc.
If you want the exact one they used in the Excellence car, I think it was an Odyssey 680. My issue of Excellence seems to have found the recycle box.
Odyssey PC680 - http://www.odysseybatteries.com/battery/pc680.htm
$85.95 @ batterymart - http://www.batterymart.com/battery.mv?p=ODY-PC680
Have a great day everyone!
Unfortunately the Aug issue of Excellence has gone off the shelves here. Did the article go into what the minimum battery specs would have to be for a track 944, ie mimimum cold cranking current amp/hours etc ?
Karl,
I put the Odyssey in my car. I can show you how to put it in without cutting and drilling and you can use the stock clampdown, so you can always go back to the standard battery. I use the stock battery for the winter and Odyssey for race season. PM me and I can give you details of what you need, or you can call/come around
I've done the same and it worked out VERY well. I'll see if I can get a pic up.
Regards,
Regards,
