Purpose for timing belt cover breather hose?
Old 08-10-2006, 10:49 AM
Olli Snellman
Olli Snellman's Avatar
On '90 &´91 there's not even a hole in cover.Also there is not a possibility to connect a hose to aircleanerbox.
Old 08-10-2006, 11:18 AM
Sam Lin
Sam Lin's Avatar
The vent and hose were removed per the TSB due to hydrolock issues. Water getting into the belt covers on the lower part of the engine was carried up on the belts to the vent and then sucked into the intake.
Sam
Old 08-10-2006, 12:18 PM
OriginalSterm
OriginalSterm's Avatar
I covered mine with some high performance electrical tape (blue too).
Old 08-10-2006, 03:02 PM
kevincnc
kevincnc's Avatar
Well I'm an idiot. I saw last night that my belt cover hole is molded shut, so I just need a cap on the airbox. Sam that makes sense about sucking in water. Thanks guys.
Old 08-10-2006, 05:43 PM
testarossa_td
testarossa_td's Avatar
If it is shut from the inside, just shave it.....
Old 08-10-2006, 06:07 PM
kevincnc
kevincnc's Avatar
I could cut it out, but now it sounds like the hose should really not be used, so I'm going to cap the airbox. In fact if I had an older car with the hose I'd probably cap it too to keep water from being sucked into the airbox.
Quick Reply: Purpose for timing belt cover breather hose?
