Aftermarket Catalytic Converter
Old 08-04-2006, 11:26 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
The metal cats flow better because they have less 'holes per inch'. I.E. the honeycome holes are bigger.
Rogue
Old 08-05-2006, 12:44 PM
jacklet
jacklet's Avatar
don't know how they will flow as compared to a random tech. cat, the metal cats have less of a catalyst inside them so they may not be as effecient which means no pass on emissions-i really do not know i was thinking of picking one up and seeing how it performs
Old 08-05-2006, 01:17 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I've been eyeing the SFR testpipe with swap-able cat.
Old 08-08-2006, 07:25 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
I have the full Cargraphic stainless exhaust system on my S2. It includes a low restriction 100 cell racing type converter. My emissions were only slightly higher (and still quite low) when I ran it through this year. I think most cars would pass without a converter. My son's '89 951 did when he was running the cat bypass pipe.
Old 08-08-2006, 08:22 PM
jturbo
jturbo's Avatar
Tom,
How does the SFR swapable cat work with the "test pipe"? Can it be used with the stock exhaust system?
Old 08-08-2006, 08:42 PM
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
Don't know anything about the SFR system, but I'm sure Turbo Tim does
Old 08-08-2006, 10:36 PM
jturbo
jturbo's Avatar
Calling Turbo Tim. Calling Turbo Tim. Do you read me? Over.
Old 08-08-2006, 10:50 PM
rcatherton
rcatherton's Avatar
I have the SFR system and normally run the resonator, however I did buy the cat to use when needed. The cat did a good job when I went through emissions recently in CA. It is set up to slip over the three inch exhaust on one end and has a square flange on the other.
Old 08-08-2006, 11:04 PM
jturbo
jturbo's Avatar
Is it a REAL functioning catalytic converter? Or just "appears" like a Catalitic Converter?
Old 08-09-2006, 07:14 AM
danny951
danny951's Avatar
I wonder if most 951s would pass without a cat. When they test emissions they are not going to be running in boost so that would probably help keep emissions low I would guess.
Quick Reply: Aftermarket Catalytic Converter
