Balance shaft housing re-sealing ???'s
Defending the Border
Rest In Peace
Rest In Peace
I this doable?
- Loosen balance shaft gear bolt, set crank to TDC (skipping flywheel lock)
- Detension belt and remove from top balance shaft gear
- Remove gear
- Unbolt housing, reseal, reinstall
- Replace belt, tension, check timing
- Remove gear
You need to remove the rear balance shaft cover to get the housing off, which will require pulling the crank pulley/gears, which will require a flywheel lock and removal of all the belts.
Rest In Peace
Rest In Peace
PHP Code:
I have the lock, I'm just trying to shave minutes off my pit time. With the Iceshark batt cables, there's a little more "configuration" than normal.
I just discovered the M13 bolt under the turbo supply line has sheared off about 2 threads down from the shank, that just doubled the repair time.
Rest In Peace
Rest In Peace
So, it sounds reasonable? Seems like it to me.
PO cut a slice in the rear belt cover to facilitate ???, this alows me plenty of flex to get the front seal housing off the shaft.
Rest In Peace
Rest In Peace
*UPDATE*
Once you detension (meaning keep enough tension that the belt doesn't skip teeth) there really is no need to do TDC or remove the pully. I'm sure the lower shaft is the opposite.
And I dodged a snapped bolt today! After the PBing, wake up, and setting the vise grips on mame, I unscrewed the silly thing with my fingers.
Not to hard to see where this was leaking at.
