running rich in hot weather?
Basic Sponsor
Is it normal to run a bit richer on hot weather? I was driving today and I noticed my WB gauge showing 11:2 at wot. When i dialed my car a/f ratio was a cool day.
TIA
Lart
TIA
Lart
air is less dense the warmer it gets. If you set it on a cool day, and it is now almost 100F there, there should be a difference. How much? Not sure. Mine does it too.
Cold weather means denser air and leaner AFR's. An older BMWCCA and SSCA racer/builder told me he always tunes the car for the coldest tracks he will run in, to prevent burning a valve or worse.
Basic Sponsor
Basic Sponsor
Originally Posted by danny951
Would a 951 with a MAF sensor and correct chips be able to correct for the denser air on a cold day and supply more fuel to the mixture?
This has been seen on at least 50 datalogs.
Basic Sponsor
Originally Posted by special tool
Yes the Vitesse system on my car compensates 100%.
That Guy
Originally Posted by lart951
My Lindsey racing digital MAF is has the air temp. sensor but I guess is not working?
I've also noticed richer A/F ratios in hot weather. I originally tuned my A/F ratios in summer weather. I then found that in New England winter conditions I was running too lean under WOT. I retuned the A/F for cold weather but now I run too rich in the summer.
That's one reason I've decided to try a Vitesse MAF setup, which is supposed to maintain constant A/F ratios, independent of temperature. I guess the special Vitesse "MAF chip" may have something to do with this. My Vitesse kit should be arriving shortly!
Basic Sponsor
Originally Posted by TurboX
maybe the difference in quality between vitesse and lindsey??
I have LR maf and Mafterburner, i tuned my car when it was 65° and AFR is 13.8-14.8
nothing much changes when i run at 100°. The only differnece is little rich at idle when it gets hot
it is around 12.8.-13.5@idle.
