Venturi?
Can someone give me a list of the size and # of hoses i need to buy to do a venturi delete, and also a step by step procedure. I have the linsey vacuum line kit and have done the other exposed lines.
3ft of 3/4" heater hose, 2 male/male 3/4 adapters, umm..., if you can 3/4" 90 degree elbow for top of aos. Hose clamps, and something to plug the jboot. Also are you using a boost controller since you wont have the cycling valve? I remember i bought some 3/8" hose, but for what...? Probably not for the venturi!
But, this doesnt replace all the kinked factory hoses, but allows you to delete the venturi. Mine werent to brittle so I left them so I could go to sebring!
But, this doesnt replace all the kinked factory hoses, but allows you to delete the venturi. Mine werent to brittle so I left them so I could go to sebring!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Its real easy. Probably 30 minutes to pull it all off. Start with intercooler pipes, then the fuel rail, then the 2 bolts on the rear of the IM, 1 hidden bolt in the front of the IM, the little bolt that holds the dipstick, disconnct the throttle cable. Leave the Throttle body on (much easier), then the 8 IM bolts and voila! And when your in there definetly replace the vacuum lines with sylicone ones from lindsey! I would very much so also reccomend a 5 port laust vaccum manifold. It all sounds a little complicated but once its all apart its plain as day!
One quick highjack if I may, when I did this all, I lost 2 hg of vacuum pressure!!! Sucks, anyreason why???![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Dont worry thats not common though, At least i think, I heard one other lister with the same experience(a red 951, dont know his name offhand)
And if you want to replace the ISV hoses at the same time:
https://rennlist.com/forums/showpost...6&postcount=30
