ALL NEW VAC. LINES.......no diff.
Originally Posted by a4944
How long should the pressure hold when you pressurize the system? I did the fuel filter in the J-Boot method with a bike pump. It pressurized to 10 PSI no problem but would go down to 0 in about 10 seconds or less so I had to keep pumping. I did find a major leak in boost line from the intercooler pipe and fixed that (it was causing stumbling on boost). The cycling valve is leaking at the electrical connections but I did a search here and that is common. Should it hold pressure longer or should I expect to have to keep adding air? Do I need to plug any lines out of the J-Boot? I sprayed soapy water and listened for leaks but did not find anything beyond the two I mentioned.
Thanks,
Mark
Thanks,
Mark
I cut a fuel filter in half. I bought tire stems, they came in a two pack and are available at any auto parts stores. There is a rubber bulb at the bottom of these. I worked that into one of the fuel line connections on the haf of the fuel filter. It will only fit into one. I had to work it back-and-forth to get it all the way in, it's a tight fit.
I removed the AFM (air filter box assembly). I then inserted the half fuel filter into the black J-Boot in which the AFM was removed and used the clamp already there to secure. I don't have a compressor so I used a hand bike pump with a guage to pressurize. I heard a hiss under one of the intercooler pipes and it was coming from the vacuum line from the banjo bolt, it was split. I was sprayed soapy water around looking for bubbles.
I read that some plug certain lines out of the J-Boot but I did not do that. I'm not sure how long the pressure should hold. I had to keep pumping the bike pump to get pressure which made it tougher to find leaks.
ArnnWorx has a how-to. He used a fitting for a compressor. He also apparently makes a tool so that you don't have to use the J-Boot and fuel filter. I have read where others got some PVC caps from hardware stores instead of using the fuel filter.
http://www.arnnworx.com/boost_testing.htm
This method did help me find some problems but I don't know how long the system should hold the pressure.
Thanks,
Mark
Thanks,
Mark
did you replace the o-ring in the venturi? You could have a vacuum leak there and it will be pronounced after replacing the vacuum hoses and possible stopping other minor leaks in the process.
Originally Posted by Andial951
anyone ever experience a vacuum leak which affects the brakes? I have one and cant find the leak.
