Sunroof Issues
Rest In Peace Jaak
Cable Guy
Cable Guy
Sunroof Issues
Yesterday I tried to open the sunroof and heard a whirring noise coming from the rear. The sunroof opens but not equally in height. I try to close it and the drivers side stays up about a 3/4 of an inch. I have to turn off the ignition and turn it back to position 1 (ignition). I then press the position A and the drivers side drops down equal to the roof line. I had to open the drivers door and manually lock the door. Whenever I use the central locking or used the key in the lock ... the drivers side pops up again. I presume the plastic gear is damaged somewhere in the headliner? It seems both sides work equally but are now off.
Are there somethings I can loook for to fix it?
Sorry ... forgot to add that it's the early model sunroof system ... pre Feb 1986 (built in November 1985).
Mine pop'd today at 140MPH on the autobahn. Drivers side did not want to go down all the way. Striped gear is what I think!
They want $9.95 a gear at www.automotion.com. www.clarks-garage.com has a hell of a write up on fixing the dang thing. Looks like a springtime Samtag or Sonnetag job.
Rest In Peace Jaak
Cable Guy
Cable Guy
Went thorugh my frinds second floor stockroom and found an update kit for the early (pre February 1986) sunroof lifting drive gear. You keep the existing motor and only replace the lifting cable assembly and assorted connecting hardware. There is a write-up in the 944 factory manual on page 61-18a.
I am getting mine replace next week ... it has the plastic gears which is easier to replace. This part is available from Porsche as it is in the latest database issued by them in July 2006. I will not post the price as it is in CDN $ and I know the dealers price. I am getting it for free .... did some work for my friend!!! The replacement is fairly easy with a slight bit of modification required ... wrench is doing it for me with me helping!!!
P/N944 564 941 00
P/N944 564 941 00
What I could see from clarks is that the sun roof gear for my 1987(the one that the arms connect to and the cable turns is part # 944-564-430-01. I was not planning on doing a change over to a new system but insted replacing one gear on one side.
Rest In Peace Jaak
Cable Guy
Cable Guy
