WTB: Stock banjo bolt...
I took one off of a spare power steering rack I had when I removed the jetted bolt that was installed on my car.
It uses the 6mm allen head, but otherwise works just fine.
BTW Zero10, I love that avatar!
-I'm about to take a pic of mine when it gets to:
123456 -on the top row
789.0 -on the bottom row...
Anyhow, I looked on the Lindsey racing site and I see "Banjo bolt at hard pipe" (click to see the link)
Presumably this is the one I need to replace the jetted bolt that I've been using with the LBE? -This is so that I can use the Boost Enhancer, BTW. -Should I also replace the sealing ring(s)? -they're cheap enough... $5.50 for the bolt and a buck for a sealing ring: -at those prices, why buy used?
I AM looking at the right part that needs to be replaced, -yes?
TIA,
Keith
TIA,
Keith
You can just remove the restrictor in the banjo bolt, mine came out with a flat screwdriver.
I've yet to replace those crush washers after 5-10 R&R cycles...no problems.
