WTB oil pressure relief valve(oprv)
im diagnosing a low oil pressure problem and would hate to spend the money on a new one ...so i thought id go the cheaper way and hope someone might have one used for sale.
thanks
Doug
thanks
Doug
how low is your oil pressure? do you still have the original 3 piece valve? If you do, try taking it out and cleaning/polishing the piston and cleaning out the bore it rides in and maybe shimming the spring and see what happens.
thanks
Doug
Doug, what kind of oil do you run? has the oil pressure always been like this or has it gradually dropped over a period of time? Has there been a sudden drop in pressure? what work has been done to the car recently? I saw one instance several years ago where someone, not me, put standard main bearings in a motor that had a refinished crank, but that car made no oil pressure at all once it was warm. Have seen some problems with either incorrectly installed front crank pulley or loose front crank bolt. The oil pumps in these cars are pretty bullet proof unless you have a major failure and send a lot of shrapnel through the system.
Good luck Mark T.
Good luck Mark T.
Hey Man
Originally Posted by dougoh
oil pressure is 3-3.5 bar cold and drops as low as 1.5 bar hot... i took it out and cleaned it with brake cleaner an saw 4 bar but then i blipped the throttle and it went back down to 3 bar..but maybe ill take it back out again and do a more extensive cleaning ...like what you say to do.
thanks
Doug
thanks
Doug
