Info needed on Saturn exhaust manifold studs
Anyone have a part number for the popular Saturn exhaust manifold studs. I am putting on a new to me head this weekend and figured I would switch the studs to the Saturn one while I'm at it. Part numbers always make it easier when going to the parts counter. Also I assume that Saturn only uses 1 type of exhaust manifold stud - correct.
Thanks,
Thanks,
Originally Posted by AL951
excuse my ignorance, But why do you want to go to those studs?
are they stronger, longer, lighter?
Regards,
AL
Regards,
AL
Allows the exhaust manifold to be removed without pulling the head.
Lifetime Member
Lifetime Member
The Saturn studs have a male torx head so you can turn them in or out without double nutting. And you don't need the torx wrench cuz a 6mm 6-pt socket does the trick. Or is it 5mm, I forget and I just did it 2 weeks ago. Middle age is setting in. It's awful needing reading glasses to work under the car.
I took off a set of headers on Monday with out removing any studs. How much are these studs? Are they cheaper than the approx $3.00 per Porsche studs? That would be a very good reason to change.
