Hoop Spoler (944S2) for 951-FITMENT QUESTION
I have searched and read the threads on 968 hoop spoilers being fitted to the 951, and that the 968 spoiler is not a direct fit replacement. I did not find a definite answer to if 944S2 is direct replacement with no mods.
I would like to know for sure if a 1990 944 S2 hoop spoiler is a direct replacement with no mods needed for the rubber spoiler on my 87 951?
I am especially interested in someone who has personally done this exact replacement.
Thank you for your input.
I don't know if it is a direct one or not , but I have a fiber glass one made to fit a 944.
stephen
stephen
The "rubber spoiler hatch" does not have the brackets needed to bolt on the centre section of the lower spolier that goes above the lock. The actual "Hoop" does bolt directly on to a normal 944 glass hatch frame.
You can buy AFTERMARKET fibreglass "hoop spoiler" kits that fit directly, but the quality is iffy.
FYI: The "Hoop" spoiler first appeared on the 1990 951. Then in 1991 it came on both the 951 and the S2. (They were exactly the same on both the 951 and S2.) Then in 1992 it came on the 968, which again was exactly the same, excet the 968 hatch reloacted the 3rd brake light above the hatch keyhole. If you use a 968 hatch on a 944, the 3rd brakelight will prevent you from being able to open the hatch with your key.
So what is the easiest route to take? It seem that replacing the hatch with a 1990 S2 or 951 would be tough to find.
I can buy the hoop spoiler for $683 at the porsche dealer, but what do I do with the center section bolt? glue it on, or drill a hole the frame of the hatch or what?
And the aftermarket ones? I don't want 'iffy' quality.
Basically what's the best plan? yeah yeah..........besides leaving the damn thing alone!
Lifetime Member
Lifetime Member
Is that $683 for just the spoiler itself, or for the spoiler, under spoiler, left and right side trim and assorted gaskets... all of which are quite expensive. I suspect it's just the upper spoiler.
In order to fit the spoiler and assorted trim pieces to a normal 944 hatch you need to fabricate 4 metal tabs to hold the under spoiler, and you need to drill two holes in the window frame because the side trim pieces have an extra attached stud. There is a recent thread here on Rennlist that shows a regular hatch with the fabricated metal tabs.
Buying all the parts new will probably cost you more than a used 968 hatch... if you can find one. They are getting harder to find and as a result, more expensive too. I only paid $500 for mine a few years ago
I might just add that some of the replica spoilers are pretty good and it would cost a lot less. I was planning on a complete hatch swap however the hatch I received was in poor condition so I opted to transplant the parts. If you are looking for just the hoop portion, I have a contact that makes a good replica fiberglass replica part for probably less than 1/3 that price. I have no affiliation with them whatsoever but if you are interested drop me a PM and I will give you their email. Also, check Ebay as they do appear ever so often.
