Glad I looked under the hood...
OK, so I was about to head back from Waco to Fort Worth this afternoon and decided to check under the hood of my car for no real reason, just to check vac lines, plug wires, whatever and honestly this is not something I do very often. Upon inspection I saw a bit of seepage coming out of the #4 injector. There wasn't a puddle of fuel or even a whole lot there, but it was visible and enough to make me not want to risk an engine fire that could destroy the car I've only had for ~3 weeks now so I had the car towed home.
I just got back home a few minutes ago so now I'm writing this. I guess I need to pull out the injectors and send them to Witchhunter or some other similar service. My question to yall is, is that all I need to do? Obviously fuel leaking from anywhere is a bad thing so I just want to make sure that that is all I need to do. The fuel lines have been replaced, so do I just need to send the injectors to be serviced or should I do anything else while I'm in there?
Cast Iron Man
It's worth it to send it to Witchhunter. They replace the seals and hats and clean them and provide you before and after flow rate test data. $60 for 4 injectors and that includes express shipping back. 4 days start to finish for me.
While I could go with the reseal kit, I think the extra cost for the cleaning and flow testing would be worth the cost; I have yet to pull the rail, which I will do tomorrow after work, but I'm fairly certain from looking at it that it is just the injector seals; it doesn't look like a drip from the rail itself, but I will definately check it and all the other components in the area to be certain
thanks for the tips guys
Definately check the fuel rail closely. I have seen one leak down the injector before making it look like it was the injector leaking. I never could find the crack in the rail it was so small, just the general area.
Yes, the extra expense of the cleaning and flow testing will be worth it if you plan to stay with those injectors for awhile. If you plan to up the boost and need bigger injectors anyway, may not be worth it to get them cleaned and tested. Especially if they flow test poorly and you have to replace them anyway.
Mine was leaking in the exact same place... #4. It was because the rear mounting bolt hole in the intake was somewhat stripped. So, I tapped the intake to the next size bigger hole, and put studs in the intake. Now the fuel rail seals well!
Here is an important point tthat I never see mentioned.
You MUST put the rail down SQUARELY - that is, if you pop on 1 and 2, then pop on 3 and 4, you will chaffe the outside of the top seals and it will leak.
Keep the rail parallel to the cam tower.
