oil on top of the filler neck????
i replaced the hose that goes on the top and still seems getting oil leaking there..i think this is only under boost any ideas on whats going on?i replaced the venturi with hoses if that helps
thanks
Doug
thanks
Doug
i think ive found the problem...im wondering if i had hooked up the aos hose wrong...does the aos hose go to the intercooler or between the mass air and the turbo?i hooked mine up to the intercooler pipe and that is causing oil leaks...i hope i am right about this ..can anyone let me know ?
Doug
Doug
Originally Posted by riotas
Wow. It should be between the maf and turbo.
If you hooked it after turbo you would send pressure to the aos.
yep... i ve taken this apart a dozen times and this last time i deleted the venturi and i hooked up the hoses wrong and sprung more leaks...i switched them back and tomorrow i should be oil leak free(i hope).thanks for verifying
Doug
