Stuck wastegate diaphram housing?
I pulled my wastegate with the intention of shimming it, as my car is showing all the symptoms of a weak wg.
I removed the three 6mm hex bolts and attempted to pull diaphram housing off per the instructions on Clark's garage. However, no matter how much pulling I do, the housing refuses to budge. It pulls to the extent of the spring, and then will not move any farther. I've even attempted two prybars on either side, though I limited the amount of force I was using at that juncture out of fear of damage.
What's the dealio?
What's the dealio?
