Boost problem
Boost problem
Does anyone of you guys have an idea what might cause following symptom:
With cold engine boost 1,2 bar ,with heat soaked engine boost varies between 0,8-1,0 bar.
Friend's car; LR Super 65 turbo ( one year old ),MAP,dual port wastegate ( original body just converted with new "bell" ),BoostSciences MBC.
I had a leak on my BOV connection on the boost connection. It would only leak when the rubber hose got warm and as boost developed. Everything looked OK when inspecting because the vacuum at idle would suck it back on good and snug until the next boost.
