Rage????? :)
Drive-by provocation guy
Rage????? :)
Anyone talked with Rage lately?
Just came accross this. I forgot how much he has done to his car.
And notice the "28" psi!!! See, with good tuning, anything is possible
1987 Porsche 944 Turbo. Built by Alpine Autowerks. Tuned by me .
Modifications :
Engine
Custom 2.8L 951 block
JE 106mm forged pistons
Total Seal rings
Modified Oilpan (oil pickup changes)
944 N/A Lightweight crossdrilled crankshaft
Extrudehoned intake manifold
O-ring'd block
Hybrid metal head gasket
3 bar Fuel Pressure Regulator
1000cc injectors
Test pipe
Legendboy charge piping
Greddy Air/Oil Separator
Turbo
Garrett T04E 60trim 0.70A/R compressor housing/KKK #8 hothousing Stage 3 turbine wheel
Tial 40mm wastegate
BMS Blow off Valve
Electronics
SDS EM-3F Spark and Fuel Management
Apex-i AVC-R Boost Controller
Blitz Power Meter
FJO Wideband O2 Datalogger
Drivetrain
Porsche 951 Rothmans Cup Racing Tranny
Kennedy Engineering 3800lb Pressure Plate
911 Turbo clutch disc
Suspension
Ground Control Coilovers w/450lb springs
28mm rear torsion bar
Koni "Yellow" rebound adjustable shocks
968 M030 swaybar
Brakes/Body/Wheels
Porsche 924 GT-R Headlight Conversion
18x8.5 OZ Montecarlo's Front (235/35-18)
18x10 OZ Montecarlo's Rear (265/30-18)
13.1" 993 Twin Turbo Cross Drilled rotors
4 Piston 993 Twin Turbo calipers
Dyno Information (2.5L) :
280rwhp - 12psi pump fuel (Mustang Dyno)
380rwhp - 20psi pump/MS103 mix fuel
438rwhp - 25psi MS103 fuel
460rwhp - 28psi MS103 fuel
Dyno Information (2.8L) :
323rwhp - 12psi pump fuel (Mustang Dyno)
349rwhp - 15psi pump fuel (Mustang Dyno, approx 394rwhp Dynojet)
Performance (2.5L) :
0-60 : 5.5s (not a typo... turbolag!)
1/4 Mile : 12.7@117mph (street tires, 25psi, traction limited RaceCity 3700ft elevation)
RCMP Laptime : 1:29.8 (pump fuel, street tires).
Performance (2.8L) :
1/4 Mile : 12.9@112mph (street tires, 15psi RaceCity 3700ft elevation)
The videos... Please right click and save to your local hard drive before viewing. Thanks.
951 Drifting Video HDTV (13.7MB)
951 Drifting Video SD (4.3MB)
The first dyno video. 340whp pump gas:
http://www.virgeweb.com/rage2/944t/...0951%20dyno.wmv
The drag video. Low boost and easy launch in 1st and 2nd, 12.7@117mph 0-60 in 5.5sec:
http://www.virgeweb.com/rage2/944t/...51-12.7@117.wmv
Low boost pump gas lap around roadcourse:
http://www.virgeweb.com/rage2/944t/...o%201%20lap.wmv
In car vid of above:
http://www.virgeweb.com/rage2/944t/...0Roadcourse.wmv
Modifications :
Engine
Total Seal rings
O-ring'd block
1000cc injectors
Test pipe
Turbo
Tial 40mm wastegate
BMS Blow off Valve
Electronics
Blitz Power Meter
Drivetrain
Suspension
968 M030 swaybar
Brakes/Body/Wheels
I had non-forged rods (regular on 91 models) no "rarst" written on them. and I did same amount of boost and nothing bend etc.. but I did not have stroker but stock engine! 550nm
Originally Posted by AL951
That is true. Can you imagine forces that are present in a F1 car revving at 19K?
the crank must be super strong to survive.
Regards,
AL
Regards,
AL
Suspension
968 M030 swaybar
968 M030 swaybar
