Please help with vacuum graph
I'm changing my vacuumlines to new lindsey ones.. I recieved a graph over the vacuum lines in lindsey's kit, although I've searched this forum as well and I've seen other graphs as well! Like these bellow.. Which one should I use with my '91 turbo with dual port wastegate and electrical boost controller? I guess it's the one with the dual port wastegate on it, right? But there's another difference between the graphs bellow; in one of them it says "AOS" (atomsphere??) and in the other "plug", on the air intake.. Should I leave that connection open or should I plug it??
The top one, except you'll have to go to the electronic controller then to the wastegate. AOS, air oil seperator, the hose on top of the oil fill goes back to the J boot or J pipe. You can plug it if you take that hose to a catch can like in a track setup.
