MBC before or after CV?
Yes I am also wondering this question. I will be installing lausts vacuum manifold and would like to delete the cycling valve and add an MBC. An info on how to do this would be great. BTW dont think thats jacking this thread at, hopefully it helps!
Run a line from the intercooler pipe banjo bolt to the MBC (disconnect the existing line that is attached there (the other end of that line goes to the CV, so you don't need to plug anything). Run the other end of the MBC to the wastegate (if we are talking a single port here). Take the one line that runs to the j-boot (it comes off the metal line in front of the intake), and remove the hose and plug the hole in the Jboot. Unplug the CV and remove it if you would like. I would pull the intake and remove the metal venturi tube entirely and the CV and bracket. If you remove the bracket, you must use a thick washer in it's place on the mounting bolts when you put them back in, or the bolts will bottom out in the head before getting tight.
Originally Posted by DLS
Does someone have pictures of the engine with the intake removed?
I have a 1990 turbo so i don´t have the venturi, right?
