When upgrading to a larger turbo is it necesary to go with a new set of chips?
#47
Originally Posted by Porschefile
14psi = 14psi, regardless of the size of your compressor wheel. The actual volume of airflow does not change. The size of compressor wheels are restricted by the laws of physics. 14 pounds per square inch does NOT equal 16 pounds per square inch. This is physically impossible! The difference is due to the EFFICIENCY of the compressor wheel.
A change of the turbine side would change the VE of the engine and may also neccesitate change in fueling.
The degree to which fueling requirements change with different turbines and compressors I'm not sure of. To have everything running perfectly, you would need propperly matched chips and the ability to fine tune.
#48
Are you guys blind? Did you not read what my post said? WITHIN THE LIMITS OF THE FUEL SYSTEM!!!! If he's still on a stock fuel system then he is going to have to be MUCH more careful! He could still use the K27, though I would highly recommend running less boost on a stock fuel system (lets say ~8psi to be safe). The most important thing here is what chips he has and how they are tuned. If the fuel maps were tuned pretty crappy to begin with, then a larger turbo is only going to amplify this. A wideband or baseline dyno at lower boost would really help to verify what the a/f's look like. I, for example, upgraded to 55# injectors and a 3 bar fpr with my VR maf chips. I'm still on the stock k26/6. Since I have decent chips and the proper fuel system, I could throw on a 27/6 or even a 27/8 and the chips would still function fine. The 27/8 spools up a bit later, so my a/f's would be a little rich, too early in the rpm. This will hurt spool and performance a bit, but not to the tune of 50rwhp or anything. For optimal power, yes I would need to fine tune the maps, though in my case a piggy back would work just fine. Do you guys see what I'm getting at? Yes it IS possible to do these things, however you are going to be restricted by fuel limitations and the quality of the tune on your chips. It's not going to be optimal but it WILL work provided you don't exceed these limitations.
#49
Then what the hell is the point? That's like Dragaliscious telling people to slap whatever width of wheel that will physically fit and 'see' what happens.
Good advice would be to tell him to save the money and wait until he can everything at once, if funds are an issue. Good advice would be telling him that he needs to adjust fuel on a dyno before boosting.
REALLY BAD FUC*ING advice is telling him it's going to be OK when he's mostly likely going to be running lean with the increased airflow. Even worse advice is stating that a car tuned optimally for a K26 will need no changes when installing a larger turbo.
And for the last time, a MAF cannot adjust fuel. PERIOD.
All of you have admitted that it's not a good tune so why tell him he can IF he sets all these limits. That's bull**** and horrible advice. Shame on all of you!
Peace.
#51
On a final note, to answer IPSC's question, you really need to upgrade your fuel system if you don't want to risk damaging your motor. This of course includes a higher pressure fpr and larger injectors which will need a retune to work properly. Yes, if you really wanted to, you could probably get away with running low boost (below 10psi), but it's really a matter of what you are willing to risk and how well your chips are tuned.
Someone sell me a 27/8 so I can throw it on and prove my point!
#52
We agree,then.
I was taking issue, mostly, with Drft's posts that he can just install the k27 and call it good. There is a right and wrong way to do something. That is the wrong way.
#53
Hi,
I don't know my AFR, but like I said before the car runs and performs just find. I also get very little Knock but then the computer steps in and it goes away. so I gess my AFR is ok or close enogh.I am very happy with the change.
Regards,
AL
Regards,
AL
#54
Originally Posted by AL951
Hi,
Regards,
AL
Regards,
AL
I can't believe some of the posts lately.....
#55
Well Daniel,
to much knock is very bad for any engine. But alittle will not damage the engine. And this is what i mean by little. as you get hard on the go pedal and the turbo spools up and you are making good boost at hi revs, sometimes (not always) you can here alittle knock like for like half a second or less, the it goes away like it suppost to do. their is no problem with this. So if the KLR is working correctly it should do this. If i was getting knock every time I would accelerated, then I would be very, very worry.
regards,
AL
regards,
AL
#56
Basic Sponsor
Well Daniel,
regards,
AL
regards,
AL
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#58
WOW I did not think that THIS was going to be such a hot topic and sorry for not paying attention to it sooner. Been Busy getting ready for the first DE.
Ok Here is what lead to my question. My 89 951 came with an Autothority MAF, a set of Autothority chips and jetted banjo bolt, a k27/6 AND the best part... a blown head gasket (more on the blown head gasket in a second).
I was told this was all part of a Powerhause "kit." I have been doing some digging and it seems that the chips are (according to the one person who would talk to me at Autothority) for a k26 set up. I don't know if that was a mistake in the packaging or what. Talking to the people at Autothority is a project in and of itself. They almost hung up on me when they found out I was not the original purchaser of the chips. In fact I was asked repeatedly if I had bought them off of ebay. When I replied that I had not, about three sentences later another round of "where did you get them" was played out.
Anyway I am wondering if the mis-match of chips to the turbo could have contributed to the blown head gasket as I do NOT want to go through that again.
At the moment I am running Guru chips (that I just found out the other day) are mapped for a K26... now the fuel curve is so rich it isn't even funny so I am not worried about running it lean. I am in the process of replacing the chips YET again. I do have an Adjustable FPR and I have plumbed in a boost gauge. I have bypassed the cycling valve with a MBC. I have add a Tail wastegate and I am running no more than 15 PSI. A Piggy back / wideband is next on the buy list.
So thanks for the HUGELY informative thread, I do appreciate everyones input.
IPSC
IPSC
#60
Basic Sponsor
I'm sorry what is "dibs" Lart?
Regards,
AL
Regards,
AL
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
