How hard is it to find good used 951 pistons?
I need, oh, say, 8 of them?
I found a hand full of them last year just by asking around here. I'm sure someone has a couple 2-3 they'd let go. Do that a couple of times, get the same tolerance group, and you'll be set.
Thats the other issue original - the tolerance. Because of cylinder wear, I think its probably going to all have to be tol2.
ORLY
Heh. Nice. I've spoken to Eyal before. He is somewhat close to me.
Eyal?
Eyal?
Here are some more. Description
Brand new set of 4 pistons for a 944 Turbo. Genuine Porsche, matched set.
Porsche part number 951-103-091-01
For cylinder diameter 100,000mm. Kolbenschmidt part 90 562 600.
The set includes rings and wrist pins.
There in the classifieds.
>You can have the cylinders recoated and use tolerance group 1 or 0 should you find them. I went with Nikasil and 964 rings... <
Was it these guys who did the job for you? http://www.928motorsports.com/services/uschrome.html
How much was it, and how long have you been running with those bores recoated.
Hosrom_951 used to get these all the time for cheap. New ones too. Dunno if he still can though. I bought a used set of group 1 pistons on ebay for about $200 a year or so ago - they pop up there periodically.
No, I had a local guy do it for $200/cylinder. 0 miles since work... <
Keep us posted, thanks for the info. Also if my bores go really bad might go with .http://www.customdesignperformance.c...n_porsche.html
Pistons are alot cheaper about 650$ a set, plus if a sleeve goes pull it out replace with new one. Scoring will be less of a problem.
the local shop also machined a new sleeve and installed it as one bore was so bad it was too deep even for nikasil to patch it up. the engine is being assembled as we speak...
