Wanted : k26/6 ship to uk?
Ok the shipping costs are as follows:
Economy (surface) 4-6 weeks $43.50
Air 4-10 days $43.50
Express 2-3 days $111.75
As for the price of the turbo I would sell for $120.00 it also has a minor amout of shaft play. also hot side has studs remove and I can supply you with allen bolts for the down pipe
4th Gear
Hi Brett,
Sounds good to me - would the minor shaft play be a problem?
This would be a direct replacement for my shot turbo so I would imagine that the the studs should be ok to swap.
Is there a way I can send you a private email without publishing it on the board?
yes you can send me an email at b944patcomcast.net (replace at with @). and we can work out payment. The turbo was working fine for me when I took it out so I wouldnt expect that it would be a problem for you.
