Help me troubleshoot this "lag" issue
I just drove his car, the thing has absolutely ZERO torque at low RPM. Taking off from a stop is difficult compared to just about every other car I've driven. Blipping the throttle makes the engine slowly rev up as if the engine had a 90 lb. flywheel.
How can I check the ignition advance on the engine, and where should it be at when idling / 2000 RPM no-load.
When the car is moving it has a typical turbo lag, and accelerates fine, but the off-idle throttle response is non-existant. It's not just a big motor problem, there is something that is preventing the car from having tip in response at low RPM. Perhaps the tip in enrichment is exagerating a retarded timing issue?
How well known are the distributors for developing timing walk? Is the conductive pick-up for the ignition and fuel timing sourced from the distributor or off the flywheel?
Drive-by provocation guy
Check for vacume leaks?
As it could be aleak that once the air flow has some velocity it is ok, but at off idle or low loads there is a noticable leak.
I know I have popped one of the IC pipes before and at normal driving it was ok till I got home, but at idle/off idle I had to really work the throttle to get any response.
I'm not sure if the TB is leaking, but I have all new vacuum lines, intake couplers/hoses, intake manifold gaskets, etc. Everything under the intake manifold is new as well.
How hot has it been when you are testing the car. The stock 951, or at least mine, was very sluggish from a stop particularly in warm weather. Also your comment about a 90 pound flywheel is not too far off the mark, considering the weight of the crank assembly and flywheel, lots of built in inertia. If you have checked the compression, checked the plugs/wires/rotor and cleaned the injectors and checked the cat not being clogged, then if it is running smoothly my guess is it is normal.
To check the timing requires marking the crank pulley or trying to use the mark on the flywheel at the back of the engine. The distributors are solid unless the rotor is badly worn or lots of carbon build up is there, but in that case I would suspect you would see some uneven firing.
Yep, the timing belt just let go.
Oh well, I got good use out of this motor so now it's time for a rebuild. Thanks for the help and ideas guys.
Originally Posted by facboy
oh, so that was the problem? the timing belt was on the way out (or gone?)
The engine picked up a intermittant stalling while driving problem, he picked me up to investigate it and on the way back to my house the engine did it once and dropped power. The engine then cut out later down the road while driving and wouldn't start. The first time it cranked over after the belt broke the engine turned over a little bit then it stopped, popped the hood, gave it one last try and I heard the valve kickback.
Oh well, the motor put in it's duty.
Originally Posted by toddk911
Speed/reference sensors???
