awesome use of a v8 in a 944 (dont hate me)
Originally Posted by Ryan in SD
....yeah because everyone knows camaros for their fantastic handling
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Rennlist Junkie Forever
Hey guys..
A few points of clarification.
It's an 2002 LS1 Vette engine with headers, cam, stiff valve springs, titanium retainers, lightweight push rods, and a custom ecu and a single 3" exhaust.
It is expected to be well into the 450+ Hp range.
Drove it today. The car sounds like a Ferrari getting on it down Ventura Blvd in Studio City.
It only had 255/17's on it, but can at a fraction of a second response from the time you blip the throttle, cause the back to go sidways in 1st and 2nd (didn't try it in 3rd). The thing is BAD-***.
We just fitted a set of black powder coated Cup2 wheels (2 sets of rear 9" wheels) with Hoosier 275/17's around today. Corner balanced it (51/49 with 1/3 tank of fuel) and aligned it.
It's 2640lbs with 1/3 tank of fuel.
All I can say is that I wish I had done this a LONG time ago. And, I wish I would have kept it a full street car because it would, without a doubt, be my everyday street car for a LONG time.
I also wish it had the 600Hp engine in it.. mu ha ha.
I think we're going to do a few more of these.
Did you guys check those RacersEdge front control arms? Recognize the trick rear axles? :-)
Costs are about $6k for the engine complete, $6k for the conversion pieces (minimum) and about $6k labor to do the install. So roughly you're looking at about $18k depending on a few things... but that's a close "by the time you're done" number.
TonyG
PS> This thing is one thing that a 944 turbo will never be... reliable. Nothing like a good old fashion V8 baby!
TonyG
Tony - could you tell me what offset the Cup2's you are running in the front. I am getting a set of CCW wheels and want to run 275's in front and need to figure out the offset.
Skip
Skip
Skip Wolfe
>>>could you tell me what offset the Cup2's you are running in the front.<<<
They are the standard 17x9 Cup 2 wheel which is a 993 take-off wheel. I don't know what the offset is, but you can find it out pretty easily. All the ones we have, have had the size and offset grinded off when the wheels were either polished or powerder coated.
You have to run 2 degrees of negative to get them to clear the fenders, but that's obviously not a problem for a track car.
TonyG
TonyG
jason952
>>>I would really like to do an ls1 conversion like that, just not to my car, is the conversion easier/better in a 951 or will a 944 shell work just as well?<<<
I would think, that the conversion would be the same on both cars.
However, since you can get a "ratty" 951 for about $3k-$4k, it really doesn't make much sense to go any way but the turbo way.
With the turbo you get the turbo trans (with gearing that is much more appropriate for V8), a stronger trans, better suspension and brakes, and a more updated body.
But to answer your question, the actual conversion would be the same process.
TonyG
TonyG
Hehehe... I TOLD you I don't know squat about USA V8's!
Ventura in Studio City, huh? -I used to live on Moorpark at Laurel Canyon... was just back there a coupla months ago... So just HOW much bigger is the LS7?
Keith
Keith
TurboCab
I certainly doubt it's -18k.
Furthermore... C5's are as common as Weber White Bread. Dime-a-Dozen.
The cool factor of this car is a 10.
But... nobody can take away the race effectiveness of the Vettes.
TonyG
TonyG
RK951
>>>What are doing for brake upgrades?<<<
For now, a simple 993TT rotor and 993 TT Caliper up front, and a stock 944T caliper in the rear and a 968 M030 rear cross drilled disk on the rear, with Pagid Blue pads all around.
We'll see how that works on this coming Wednesday when our next track day at WSIR (small track) is held.
TonyG
TonyG
Originally Posted by Matt H
I dont want to be a ***** but in the head to head comparison the Camaro of the same era as the 944 was not far behind in terms of handling.
continue discussion!
Are you still useing the stock 944 transaxle and gearbox? Would the 928 be stronger? Which torque is the max for stock drive shafts, have seen you swapped to GKN?
Increadible job!! Thought it was already tight around the 951 engine....
Hey Tony,
Welcome to the club. Ive had that combination (2002 LS1 V8) for a year an a half and the only regret I have is not having done it sooner. Were we differ is that Im using a 968 6-speed and Im getting ready to get a taller ring and pinion to keep the tight gear spacing and have a lower rpm cruising speed. Im also reseaching the posibility of getting an electric brake booster to get assisted brakes.
Jpr
Jpr
