toluene or xylene sources???
Old 05-16-2006, 10:15 AM
  #31
schnellfahrer
schnellfahrer's Avatar
I'd like to hear more about the fuel line issues as well.
Old 05-16-2006, 10:37 AM
  #32
944Fest (aka Dan P)
Unaffiliated
944Fest (aka Dan P)'s Avatar
Here is a very good article I found on the topic:
http://www.europeancarweb.com/tech/0...ted/index.html
(you can read the charts at the bottom better if you save them to your PC and then view)
Old 05-16-2006, 06:22 PM
  #33
Mike1982
Mike1982's Avatar
I am watching this thread because I was wondering what kind of ratio I should run in my car. Also, about the gas lines being replaced.
Old 05-16-2006, 06:43 PM
  #34
schnellfahrer
Seems like octane-boosters work better than T
Old 05-16-2006, 07:04 PM
  #35
mtnman82
mtnman82's Avatar
Now I'm really confused ?? ??
Wasn't there another article posted a little while back that showed the additives only raised octane by .2-.3 points (yes, that's tenth's of points)?
Old 05-16-2006, 07:18 PM
  #36
DFASTEST951
DFASTEST951's Avatar
I remember that article in EC. They said toulene had detrimental effects on a motor without using other additives. I Xylene different than Toulene and is there anything else to add to the mix?
Old 05-16-2006, 09:36 PM
  #37
944Fest (aka Dan P)
Unaffiliated
Schnell, make sure you notice they only added .8 OZ of toluene per gallon. That's less than a shotglass full. We're contemplating adding more, such as 10 or 20%, as the other chart shows with considerable increases.
Old 05-16-2006, 10:18 PM
  #38
mtnman82
mtnman82's Avatar
I think I might go down to Kragen or Autozone to see if they have the NOS. 0.8 oz per gallon of that stuff raised the octane rating by 2.5 pts! Is it safe to run MMT or Ferosene in our engines (i.e. will the O2 sensor/cat be OK)?
Old 05-16-2006, 11:47 PM
  #39
DFASTEST951
FYI, I blew my third motor with 104plus in my car thinking I had 95-97 octane in my car. Took it in for the warranty and David analyzed my motor. The ONLY thing it did was turn my plugs red. I didn't follow break in procedure and turned the boost up too high with pump gas. $30,000 down the tubes cause I didn't have patience. Little grasshopper learn, even if it cost me stupid money.
Old 05-17-2006, 09:24 PM
  #40
special tool
special tool's Avatar
NOTHING works better than tolene. The 944 8 valve LOVES it.
I could write chapters - but I won't bore you all.
It is NOT just octane, it is the flame speed and energy content we need to consider.
Then you can consider my 951's 533 at the wheels - ALL on aromatic hydocarbon supplemented street-fuel only.
Old 05-17-2006, 09:53 PM
  #41
BC
BC's Avatar
Its just scary stuff, if you look at the warnings, and is difficult to get large quantities of. Do you agree?
Old 05-17-2006, 09:55 PM
  #42
lart951
Basic Sponsor
lart951's Avatar
Jim I though you said Xylene is better for our engines than toluene.
Old 05-17-2006, 09:58 PM
  #43
lart951
Basic Sponsor
lart951's Avatar
Do you really want me to comment on the above?
Old 05-17-2006, 10:18 PM
  #44
Driftomagnifico
Driftomagnifico's Avatar
All street fuel is based on aromatic hydrocarbons, so you aren't supplimenting anything that isn't already in the fuel.
93 RM/2 octane fuel can contain up to about 40% methylbenzene (toluene) as a primary knock reducing agent.
Old 05-17-2006, 10:24 PM
  #45
Driftomagnifico
Everything that is in gas carries the same warnings.
Just be glad you don't live in a country where Benzene is rampantly placed in fuel. Instead here in the US we rely heavily on MTBE.
Quick Reply: toluene or xylene sources???
